4.56's with 285/70-17's?
1882
It looks like the power wagon comes with 4.56 gears and rides on 285/70-17 tires which is roughly a 32.5 inch tire. Anybody know if this ratio would be similar to a standard 2500 with 265's running 4.10's? Reason I ask is that I am thinking about 4.56s on my standard 2500 but I already have 285s on and I'm guessing the setup would be roughly like running 4.10s with factory sized 265s. Am I close on this one? Many thanks fellas!
cux211
NE PA
it would be close to being equal +or- a little bit do a search I know there are charts out there that will answer this exactly try grizzly locker's site
WhiteExpress
Midland, TX
You'd be fairly close, the Powerwagon is still got a lot more gear though.
3749 RPM PowerWagon locked in 4th (1:1) at 80 MPH
3488 RPM 265's with 4.1s, same situation as above
32.7" Tire vs 31.6" isn't a whole lot of change in diameter.
1882
How would the PW have more gear if we both had 4.56 s and same size tires, should be the same, no?
WhiteExpress
Midland, TX
I thought you wanted a comparison between a 265 w 4.10s and 285 with 4.56?
There would be 0 difference PW to Normal 2500 with same Gears & Tires.
Maybe I'm missing something.:wave:
1882
Oh I gotcha, what I was wondering was if I had 4.56s with 285s, would that be like 4.10s with 265's. I already have 285s and am planning on 4.56s
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
285 is as big as you wanna go IMO for a Hemi and 4.56's, I've tried 4 sizes including 35,s and went back to the 285,s. 4.10,s and 265,s would be a good combo. Now 265's E rated with 4.56 would be perfect for Towing anything over 7k lbs with the Hemi.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
If you already have 4.10's, then I would stick with them. If you currently have 3.73's, then the 4.56's will really help bring the truck to life.
1882
Currently have factory 3.73s and 285s and wanting much more gear!
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
4.56's are the ticket. They will make your truck feel like a half ton.
