May-39
5.7 head-reliable setup-6.1 retrofit>
2011-5.7 4x4
jbas-intake
Backstory: lifter going
With new stock spec cam, what should I do to heads to make sure I NEVER have this problem again? ( I did search this forum first). I found suggestion and discussion but no "recipe." I'm not sure if all the 6.1 swap talk is pre 09 to current motors or if 6.1 stuff works with our 09+ 5.7 heads.??
Will 6.1 springs-rods and lifters work on the 09+ 5.7 vvt truck?
What lifters-new oem mopars proven reliable?
Springs: OEM-Pac Springs?
6.1 pushrods on both sides (int & Ex?)
My thought is I will clean up/polish exhaust ports, maybe port match to headers. Have local reputable head shop once over, do valves and springs.
I don't drive truck hard enough to justify vvt cam. If I'm spending that coin I would buy long tubes first, then converter.. Truck is weekend camping and stuff hauling rig. Rarely past 5k.
Thank you for your experiences and input
2011-5.7 4x4
jbas-intake
