anyone now how to remove the fuel line from the fuel rail
joeg45
Katy, Tx
Anyone so i can put on this fuel line adapter please and thank you
Its the connector on the stock fuel rails on a 2010 5.7l
MADDOG
Out Exploring Arizona
Yup...that's how ya do it. You need that little tool to collapse a spring collar under the connector hat.
joeg45
joeg45
Katy, Tx
Well this sucks i went to autozone and they dont have one
SmokedRam
Zephyrhills, Florida
Really? Even over in the "Help" section? Thats where I had to get mine...it was only about $7
joeg45
joeg45
Katy, Tx
I went to another one they had one but the 3/8 side is to big? ???????
SmokedRam
I don't knwo actually...mine is double ended...one large size and a small side.
joeg45
joeg45
Katy, Tx
So is mine but the smallest one is a little to big to go in and press in the tabs
joeg45
joeg45
Katy, Tx
Am i just not doing this right lol or is 3/8 not the size of the line
MF2000
Pensacola,Florida
2009 Crew Cab
Don't forget to relieve the pressure before breaking the connection. You can place a rag over the shrader valve and press lightly until the pressure is gone. You will get some gas coming out thus the reason for the rag. Be safe and wear some eye protection too.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Or an easy little quick tip is start tje truck with it running pull the duel pump relay. Let the truck die. Done. No mess aside from the little residual. Thats what I did worked great.
Sent from my DROID RAZR using Tapatalk 2
joeg45
joeg45
Katy, Tx
There is no shrader valve on this truck
MADDOG
Just pull the fuel pump fuse, start the truck to empty the lines and let it die.
joeg45
joeg45
Katy, Tx
See i got all thay done its when i go to take pff the li e when i have a problem i have the disconnect tool but the smallest size(3/8) is still to big for it ot wont go under the bell housing thing
