Just an FYI, PQIA just released
testing on 4 major diesel oils. Surprising as hell to me, Rotella doesn't have Moly, Delvac and Valvoline do. Rotella still may be the best, but I might consider running an oil soluble moly treat if I was stuck on Rotella.
I recommend this one, add to crank case, as you see it says use in all diesel engines.
Also Cummins now
recommends diesel additives, cetane boost and lubricity enhancer you add to the fuel tank.
It used to be you just run diesel for 500k miles and not touch or worry about them. But modern diesels and fuels are much different, more to consider. I'm not going to say which one is right or wrong, but research it and come up with a strategy. I know the eco diesels actually had widespread INTERNAL damage forcing FCA to make new oil recommendations. I have not heard that carrying over to Cummins. But then again the writing is on the wall. Adding a moly treatment to an oil change is cheap insurance, using additives in the fuel tank every time can be expensive. You can find
all-in-one treatments like this that may lower that cost. I believe that is everything except an anti gel, not sure there is much use for anti gel anymore, seams like gas stations in cold areas have solved that. But that product does everything else I believe with exception to the fuel catalyst. Here's the description.
Red Line's 85 Plus Diesel Fuel Additive Treatment is designed for use in all diesel engines and contains extremely powerful lubricants, detergents, seal conditioners, fuel stabilizers and rust preventatives, but without smoke suppressant. Red Line 85+ contains additional cetane improvers which boost the fuel 5-9 cetane numbers and additional lubricants which reduce wear in low sulfur fuel by 75%. This improvement in lubricity and cetane will reduce detonation, assist starting, help reduce smoking, help prevent fuel system wear and leakage and can provide 5% additional power and efficiency. This diesel fuel additive complies with the federal low sulfur content requirements for use in diesel motor vehicles and nonroad engines. Extremely powerful high-temperature detergents clean fuel injectors. Lubricants significantly lengthen injector and pump life and reduce ring friction which is very important for today's low-sulfur fuel. Both Red Line Diesel Fuel Catalyst and 85 Plus are available as a winterized version which will reduce the pour point of a typical fuel by 25°F.
