ramhornet15
sounds the same as uprev when i had my titan. The only thing i don't like is that you have to purchase a new ecm or send in your ecm, rendering your truck useless until it comes back. I have a 2015..I still want to do this sometime, the programming is worth it.
not per say
You have to marry the tuner to the truck and send a copy of the factory pcm tune.
Not as hard as it sounds
then he sends you a CMR tune, you load that then you datalog and sent the log back.
If changes are needed, he will send you another tune repeat until running like a scalded dog.
