Difference between Carven-R and Competitor?
00R/T
CT
The muffler by itself needs to have pipes cut and welded. The direct fit bolts in place of the stock muffler and can be installed with hand tools.
Orion
Orion
So whats the best option iyo?
Solid State
2011 Bighorn
It depends on if you want to have something you can direct swap in your driveway, or pay a shop to weld it in for you. The kit is a good diy option.
Orion
Orion
Would a shop even charge that much though? Would it not be better money wise to only buy the muffler and get a welder to weild the muffler in?
Solid State
2011 Bighorn
If you have dual outlets you'd also need a y pipe. Here's a couple pics of my swap. The kit comes with everything you need. Someone else might chime in on cost of having it welded in.
Orion
Orion
i think i have the single in dual out, i guess i'll just order the full kit.
Orion
Orion
You will need to cut out that muffler. No bolt in system will work for you.
Yeah i'm gonna just take it to a shop and let him do it.
