1882
- Jul 13, 2013
- 82
- 8
- 2010
- Hemi 5.7
Anyone know what exactly it is the dealer puts in the oil to quiet this down? Thanks!
Nobody is chiming in?
Did they use something, and did it work for you? What lifters need is something that is soluble in oil that stays behind when the oil isn't present. Molybdenum is a metal that in proper form acts like graphite or similar, it reduces friction when the oil is not there. Moly is soluble in alkaline and less soluble in acid, so it is perfect in your engine because if you have acid in your engine you are already in big trouble anyhow. The second main purpose of an oil behind lubrication is using it's additives to keep acid low, or alkaline high however you look at it. Lifters are dry at start, so having a coating of Moly there is very helpful. I used Redline oil and it has erased my lifter tick for the last 6 months or so. Among other traits of redline is it was the highest Moly content at the time I was researching oils. It has about ten times the Moly of Amsoil or Mobil One. I know this didn't answer your question, but I hope it helped. google moly basics and you will see how your lifters will benefit from having something like that in your oil.
I thought about using the Lucas stuff because I used it in my Toyota as well. I am just wondering if it would fool with the MDS system. I know we can only run 5w-20 or else it will mess with it...
I think I'm going to run Motul 8100 in my G8 in the future. It gets rave reviews and I've seen it matched up against RP in HP/TQ wars and it wins.
