PigSooieHailGul
- Mar 7, 2017
- 17
- 1
- 2012
- Hemi 5.7
I'm sure y'all getting tired of my issues...
Finally got everything lined out on my reman 5.7l. Now it runs like **** unless you give it throttle. I tested 2,4,6,8 cylinder and only 2 runs good. I tested by unplugging coil packs. Then swapped 2 in the others and 2 still runs good. So I swapped 2 injector with 4 and not change either. I installed new injectors anyways, had new plugs.
I been reading it could be a sensor. The massive hole was in 8 on my old motor I blew right above the crank sensor. The sensor visually looks fine but could that have damaged it?
Other things to diagnose?
