smaxwell
Information:
2009 Dodge Ram 1500 SLT 5.7 Hemi
Bought the truck with 96,000 miles on it, no idea on services before that.
I currently have 163,000 miles on it now.
3 Weeks ago:
Check engine light came on and slight misfire in cylinder 5.
Had shop replace all spark plugs, ignition coil on #5, fuel injector on #5.
Shop said was all good, literally drove 1 block down the road and had same issue show up in computer and still driving with a misfire. Engine shakes very roughly in gear, slight tremor on idle in park, but very unsafe to drive.
Once I had the truck at home I did my own work on it.
I replace all 8 ignition coils. Cylinder 5 misfire no longer in computer, but now it states P2308 ignition coil c secondary circuit. Idle is still rough, not terrible in park, and still same issue running unsafe in gear.
Tested with multimeter on every coil, receiving average of 13 - 14 volts per coil on both ends of the coil plugs on all 8 coils just to make sure I didn't have a bad wire.
I'm at a loss and could use anyone's help on this one. I feel I may need to take her to the pasture and put her down.
3 Weeks ago:
