throttle re-calibration
Glenn B
2012 Dodge Ram 1500 CC
Hemi 5.7 390 HP
Wow, they need a page like that for Rams. Theres a bunch of interesting stuff on there- I wonder how much carries over to the Rams?
In general I think there needs to be more late model Dodge and Gen 3 Hemi resources.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
browsing forums is a good start
1500ram12
1500ram12
5.9L Cummins
That would be great?
09SMOKINHEMI
TEXAS
I'm going to have to try that! good find!
quietpeen
2021 TRX
Hellcat
what does re-calibrating it do for you?
1500ram12
1500ram12
5.9L Cummins
i haven't tried but from what I've read it can help give a little better throttle response, less lag.
wwsowell
Central Arkansas
4.7L
Hell I will try it to just to see......knowing my luck I will blow the damn thing up!!!
mikeb33
2012 1500 2WD express
Did you notice the part where the SRT Engineers say it doesn't work that way?
1500ram12
1500ram12
5.9L Cummins
I haven't gone through the whole article yet
heavydrop82nd
Texas
2015 RAM 1500 crew cab sport
This worked for me
I have a 2015 ram 1500 sport 5.7 hemi crew cab. It has a push button start and this is the steps I took for a better throttle response.
Step 1. Put the the push start button to run without starting it. Let the instrument cluster cycle all the way through before taking the next step.
Step 2. Slowly push the gas pedal to the floor and hold for a second then slowly release. Do this three times.
Step 3. Start your beast of a machine and you should be good to go.
