malatu
My 2016 Laramie has 4000 miles on it. Just recently, the transmission slips between 1st and 2nd (might be 2nd and third) gears. It then slips in the same fashion between the next shift but not nearly as bad. If I immediately bring the truck to a stop and try to duplicate the problem, it will only duplicate the first slip. Also, it only duplicates the slip at about 30% intensity of the the first time it does it. After that, it will never slip again unless isn't driven 4 or 5 hours. So it only slips when it's cold and never slips when it's after it goes through the gears two times. Also, if I warm the truck up for 5 minutes, it will still slip but not as bad.
It only started doing this the last 2 or three weeks and it is gradually getting worse. I have no transmission leaks in the driveway. I assume it's going to get worse and I plan on taking it to the dealership soon, but am scheduled to to drive the truck on a 700 mile trip this weekend. Any thoughts on what's going on with the tranny and should I not take it on the trip?
