Upgrading rear sway bar
David776895
I have an outdoorsman 4x4, with stock front and rear sway bar. If I replace just the back sway bar with a hellwig (or another aftermarket swaybar), will that give me considerable difference in cornering? or do I need to replace both front and rear?
whetrick1
It would be a good idea to replace both at the same time.
Paluby
Alaska
What are you using your truck for the most?
Witch
Hemi 5.7 liter
I put on Hellwig's rear sway bar, what a difference over the underwhelming factory bar
This is one of those upgrades once you have it you can never go back :)
attachment.php
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
As already stated, the stock front 4wd swaybar is pretty stout already, so there isnt much need to replace that. The rear bar is a different story though. I replaced the stock rear swaybar on both my 2011 and 2015 crew cab 4wd trucks and immediately felt a difference. This is an upgrade that is well worth it.
D
David776895
Thanks everyone! ! !
Sent from my SM-G935T using Tapatalk
KCaudill
The RAM
Blacksburg, Va
You sell these bars Moe? I have a 2016 and would like a few add ons. Looking at the PCM upgrade as well. but worried about the warranty issues.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Yes we do. We have 34 rear bars and 18 front swaybars in stock right now.
Front and Rear Swaybars
bassheadhemi
Montreal, Canada
I keep reading that the rear sway bar on the 4x4 is 22mm, but just measured mine and it's 20mm (0.788in)
Did they shrink it on the 2015?
Sent from my SM-N920W8 using Tapatalk
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Both y 2011 and 2015 crew cab trucks are 4wd, and the stock swaybars that came on them were not only narrower than the Hellwig, but they were also hollow and half the weight. There is no question whatsoever that they are inferior to the Hellwig in a big way.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Matt, Are they larger in diameter? The reason I ask is because of the after market diff cover and the possible clearance problem.
Jay
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Jay
They are larger in diameter, but I also ran a Mag Hytec cover and had plenty of clearance. The panhard bar gets closer to the diff cover than the swaybar does.
bassheadhemi
Montreal, Canada
Will the Hellwig reduce the floating effect when changing lane and getting in the other lane grooves?
Paluby
Alaska
Ooooo good question. Our ruts up here are horrible!! If that answer is a no than what about an upgrade pan hard bar?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Are they difficult to install myself? Any special tools needed?
Install takes about 20 minutes, and you don't even have to lift the truck off the ground. Very easy swap.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Yes it does. In general, the truck just feels more planted to the road at all times.
