A direct drive system would be the holy grail for me but there's only so much effort I'm willing to put into this project, lol. I like how you think, it's a lot like me: build it so you can expand in the future. What are you running for a fuel system in yours? I've got dual Walbro 400s with a return system, I would think you're needing a triple pump for that setup. Progressive/pressure switch activated?
A CDS is definitely not without issues, but the benefits are worth it to me. But there's also the cool factor.
Nobody has ever done a gear driven blower on a Jeep. Especially one that's going to remain street legal. Alston, HHP, and RMCR at first told me no way the accessories would still work. I disagreed and we worked it out. I could tell by eyeballin' it that it would work. Just the AC comp that's still being worked out. Not sure we can get enough wrap on the power steering pump. I also didn't want the bellmouth sticking through my bumper. As you can see from the pic, that was resolved too. So it's coming together...slowly...
The previous build was running a custom in basket dual Walbro 255 setup RMCR came up with, and 80# Siemens injectors, and Aeroquip rails. The new build will be a Fore hat with 3 Bosch 450s, 1500 cc injectors, return system, with regulator, rails, etc..
I'm pushing 17psi through a 349cuin forged block and the plan is a 426 from a 6.4L or 6.2L block and be able to bring it down to a reasonable 12psi. I should be happy with that for a while but I can also swap up to a F-1X in the future, y'know, just in case. The 4L80e I'm putting in next month should hold up to that just fine.
Cool! I got 20 psi out of my V-2, but the 6 rib serp couldn't handle it. At 6k it would shred every time.
So I had to back it back down to ~16. The Vortech side of things worked fine though. Since the new build was about to happen, there wasn't any point in going to a 50mm cog setup, but otherwise that would've happened. The V-2 still had plenty more in it.
I vote for the F-1X. That's a really nice blower! The quickest GenIII on the planet is running that one. Rob Goss's Drag Pack.
Rob's build
I worked with Bill at Paramount Performance on a tranny. Already had his built NAG1. Couldn't hurt it, but it's only good for ~1000 hp. I first thought 4L80E, or maybe some TH400 variant. Neither would've been plug and play though, and Bill had already tried prototyping each for his Jeep. An 8.0 second monster and quickest Jeep on the planet, so far. LOL! Anyways he didn't think either would hold up to Pigzilla's power. But he had taken his built NAG1 and made it even stronger. TH400 input shaft, customized converter, clutches, etc.. But it's gonna break too. I know that going in. Big power means things break. But Bill believes it'll hold up better to my abuse than the other two.
Bill's Jeep
Anxious to see what you do with your rig. You may do your own engine. Wish I could still work on my stuff... But if not I highly recommend a HHP/BES Hemi. Both Rob and I have the same internals, but he went for a little stroke. But nobody builds a Hemi like Tony Bischoff. He's won the Engine Masters Challenge something like 7 or 8 times now. Nobody can touch him. And I know why. My engine just keeps begging for more and more. After seeng what Rob's engine did, Bruce at HHP told me I could throw whatever I wanted at it. So I am.
Sorry for being long winded, but I'm somewhat obsessed with this stuff.
wink
