Good read:
https://www.oildepot.ca/dodge-dealer-home-of-1000-atf-flush/
Yup here it is listed on Redline webpage down at the bottom.
Synthetic D6 ATF is a lower viscosity version of the D4ATF and is designed for better fuel efficiency in CAFE testing. Dexron VI requires a different approach to a conventional ATF formulation. Rather than beginning with a 7.5 cSt fluid and allowing a viscosity loss in use to drop to 5.5 cSt, the Dexron VI fluid requires a starting viscosity of less than 6.4 and a final drop to no less than 5.5 cSt. Red Line D6 will drop to no less than 6.1 cSt. Since the final viscosity after use of these fluids are similar, Dexron VI fluids can be used where Dexron III fluids
were previously recommended (with the exception of some manual transmission applications, our customers report).
D6 ATF also provides significantly improved gear protection and will provide a GL-4 level of gear protection. The balanced frictional characteristics provide smooth and consistent shifts for extended drain intervals. The superior stability compared to petroleum ATFs allows high-temperature operation without varnishing valves and clutches which leads to transmission failure.
Popular product and application crossover:
Dexron® VI (GM #88861003), Mercon® SP, Mercon® LV, Mercon®, Dexron® III '99 on automatic applications
BMW - Dexron® VI - BMW #83 22 0 432 807, 83 22 0 397 114
('06 on 6L45E X3, 6L809E, '07 on 3 Series, '08 on 1 Series with GM GA6L45R 6 speed automatic)
Ford Mercon® SP - XT-6-QSP
(Torque Shift 5-speed Automatic 5R110W, '03 on 6.0 liter diesel trucks, 2005-09 V-10, ZF 6HP26 6R60/6R75)
Ford Mercon® LV - XT-10-QLV
('08- Focus, '09- F-150, F-250SD, Expedition, Navigator 6R80)
Honda/Acura DW-1, Acura ATF Type 3.0
Mercedes Fuchs/Mobil/Shell 3353, MB Sheet 236.12 (NAG-2, 722.9,
7 speed transmission - MB # A001 989 45 03 10)
Mercedes Mobil/Shell ATF 134, Fuchs/Titan 4134 (MB Sheet 236.14 NAG-2, 722.9 7G-Tronic supersedes 3353, MB # 001 989 68 03 10)
Mercedes - Dexron® VI MB Sheet 236.41 (722.550 8 speed
ML Class hybrid type 164.195)
Mitsubishi Dia Queen ATF-J2, Mitsubishi # 4040610, 4031610
Mitsubishi SP-IV - Hyundai SP-IV - Kia SPH-IV
NissanMatic S
Toyota/Lexus WS, AW-1 - JWS 3324, NWS09638
(VW/Audi 0C8 8 speed # G 055 540, SAAB '03 on 9-3 6 speed # 93 165 147, Volvo # 31 256 774, 31 256 775)
ZF Lifeguard 6 & 6 Plus - Shell M1375.4
('02 on 6 & 7 Series, '06 on 3, 5 Series and X5 with ZF 6 speed automatic BMW# 83 22 0 142 516, 83 22 0 144 137, 83 22 0 406 929, VW/AUDI # G 055 005, G 055 162 )
ZF Lifeguard 8 - Shell M-L12108
(BMW # 83 22 2 152 426 and VW/AUDI # G 060 162)
Dexron is a registered trademark of General Motors Corporation.
Mercon is a registered trademark of Ford Motor Company.
I know when I do my 8 speed service....I'll be switching to redline and an aluminum pan with higher fluid capacity as well as a full synthetic fluid.
