Lamp Out?
BAMA BOY
Gasden,Alabama
4.7 Liters of fire breathing fury!
I'm getting the lamp out alarm randomly, and can't seem to find any light that is out. Any help will be appreciated and I promise pictures of the new stuff are coming!
adamwilkes14
wouldnt an error cancelling harness solve that problem with the HID? I have head of people getting them with LED tail conversions too.
AWE Daniel
Banned
There are a few ways to trick the computer if you have HIDs, I find the capacitors the easiest.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I don't have HID's and had this problem. Couldn't find a light out. Going down the road I'd get a random bell. Turned out to be the rear driver side light bulb had a slightly corroded socket. Cleaned the socket, changed the bulb and used some dielectric grease and all has been well since. Good luck...
badfish888
Va beach
2012 hemi express
I just got rid of that problem!!!!!!!, my front passenger headlight plug, had corrosion on it, took off bolth from ones, wire brushed and contact cleanered, re assembled and have not had the chime in over a month
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
check the taillight board, they are notorious for this.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
My pass side tail light board kept eating lights till the 5th one I finialy gor dodge to put in a new one after they said nothing was wrong...
BAMA BOY
BAMA BOY
Gasden,Alabama
Thanks for the info guys ill start checking for corrosion and btw the hids aren't installed yet
