triple111
- Jul 7, 2016
- 25
- 6
- 2002
- 4.7
So my friend was helping me with my truck, and he noticed fluid stains on the Front Right frame by the brake line.
Looking at the brake line, it looks like it is a little scuffed, I can't tell if its just the rubber coating that is rubbed up or if the line is busted up.
I put a piece of paper towel down to see if it was leaking while driving and so far it looks completely clean in the area that the line is. There is a small yellow spot indicated in the spot where the arrow is, but I believe it is from my heating core, as it is right above the leak spot (which is leaking as I smell antifreeze inside).
We tried pumping the brakes, which didn't cause anything to come out of the line. The brake fluid level is normal, and the brake feel fine to me. I think it is just fluid from my heating core all over the frame, but he is convinced its the brake line. We saw yellowish drops of fluid when the leak was wetter.
