my front end...
Looooong'021500
my truck is an 02 1500 crew cab long bed, when I got it used it had the front end lowered a couple inches. I prefer MY truck not to be lowered so I looked at the setup and didnt see anything obvious about how the lowering was done. My best guess was that the coil springs had been changed out or cut/grinded and so i bought new factory springs from mopar... the factory springs lowered the front another 2 inches!! Im not a big mechanic, I have a decent knowledge but not much experience, can anyone give me some ideas on why stock springs lowered my truck even more, it is sitting on the bump stops its soo low?!?!
L
Looooong'021500
my front end
AWE Daniel
Banned
Take some pics so we can see what is going on there. Trucks from the factory are supposed to be about 2 inches lower than the rear.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Im guessing by you using srpings your a 2 wheel drive correct?
L
Looooong'021500
the truck is a 2wd, in the last 2 weeks i hae replaced te shocks all the way around and I replaced the tie rod ends, upper control arms with ball joints, and lower ball joints with the springs. I will have a few pics posted in a couple minutes...
L
Looooong'021500
956-suspension-lower
ramhunter9
P-Star Jeep Wrangler
that sucks , I noticed you had the same question in another thread i merged them for you . This is the correct location .
AWE Daniel
Banned
uhh the pics didnt work, try photobucket
AWE Daniel
Banned
try to get some pics of how your truck is sitting now too please.
Also if I am not mistaken, from the factory, the springs have a rubber spacer sitting on the top or the bottom. I hear lots of guys when they do their levels they add their spacers and keep the factory ones too. I think the factory spacers give you an inch or so. Are those on there?
southernbnb
you sure those are factory springs? cuz the ones on my 04 2wd are alot taller than that.
L
Looooong'021500
the stock rubber spacers were on the old springs and I put them back with the new ones, on the top, but they werent thick enough to give it any extra height. here is how the truck sits now.
AWE Daniel
Banned
Ill go snap a few pics of my front suspension real quick im gonna wash the truck anyways hang on a few mins
L
Looooong'021500
the new springs that i put on were bought on mopar-wholesale.com for $42 each, everywhere else online only had +6 lift or -2 lower springs, and the parts stores were gonna cost $80-90/spring with minimum 5 day wait to order them.... so far im looking at putting the old springs back on which would lift it back up about 2" (strange to me because the new ones were the same size when I laid them next to the first old one that i removed) then possibly getting +1 1/2" spring spacers
AWE Daniel
Banned
I dunno yours looks a tad shorter to me but here is mine. Your truck doesnt look like its sitting obnoxiously low or anything but if you go back to the other springs and put in a spacer like that than you are probably gonna want longer shocks too.
L
Looooong'021500
the new springs were the same length as the old ones while they were sitting on the ground but once it was in the truck it compressed alot more than the old ones... Daniel, how much space is there between your lower control arm and the bump stops? before the switch I had about 2" but now its sitting on the bump stop...
ramhunter9
you got the wrong springs sent to you sounds like to me ? do these 1500's have t-bars ???
get what im sayin ??
L
Looooong'021500
i thought of adjusting the torsion bar, but it doesnt have 'em
ramhunter9
didnt know, it has been awhile since i had a IFS truck just a thought but since you dont have t-bars , never mind
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
RH it was the 4x4 that have tbars because there wasn't enough room for springs and the halfshafts. Our trucks have tbars or springs not both. And I agree sounds like he got the wrong springs
