Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > General Discussions
General Discussions
Vibration at idle only.
This is a discussion on Vibration at idle only. within the General Discussions forums, part of the 3rd Gen : 2002 - 2008 category!
So after getting the truck back from the transmission shop to have the second gear band replaced I have this ...
Reply
Old 12-07-2016, 11:03 PM   #1 (permalink)
Adam/'s Avatar
Ram Year: 2007
Engine: 5.9
Default Vibration at idle only.
So after getting the truck back from the transmission shop to have the second gear band replaced I have this vibration felt through the seat and pedals. As soon as you accelerate or rev up the engine slightly it goes away. Its one of those "it didn't do this when I dropped it off" things. The transmission shop went back though but came up with no answer. They also rotated the torque converter thought all six bolt up position with no change.
Took it to a second shop, one of the techs came out and rolled under it to look around. After a quick look to make sure nothing was touching the body he told me that the motor mounts look like they have sunk as in the through bolt is really close to the upper mount housing with virtually no mount rubber showing at the top so this "Might be the cause". I have really never looked at them so I do not know what normal looks like.
So before I spend money on a "might be" I wanted to see if anyone has any thoughts or even a been there done that would be great!
There are no codes set and I already inspected the balancer to make sure it had not spun.
Sponsored Ad
Register to remove this ad.
__________________
2007 Ram SLT 2500 Megacab 5.9
Adam/ is offline   Reply With Quote
Old 12-07-2016, 11:21 PM   #2 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2014 Big Horn Crew
Engine: HEMI 6.4L
Default
yeah, that's a plausible explanation. It could also be the transmission mount back at the tailshaft/casing. Did you have the transmission mount replaced with the R&R work done on 2nd gear?
__________________
MICHAEL
SUPER MODERATOR
2014 BIG HORN CC / 6.4L HEMI
AFE / ARMA COAT / BFG KO2 / DIABLOSPORT / HEMIFEVER
MAGNAFLOW / N-FAB / PIAA / PRO TECH / TUFF COUNTRY / WALKER EVANS RACING
MADDOG is offline   Reply With Quote
Old 12-07-2016, 11:45 PM   #3 (permalink)
Adam/'s Avatar
Ram Year: 2007
Engine: 5.9
Default
Thanks for the reply. No they said as the second tech that the transmission mount was fine. The transmission shop to determine this removed the bolts and jacked up the rear of the trans and said it did not help.
__________________
Old 12-10-2016, 05:21 AM   #4 (permalink)
Ram Year: 2007 Ram 1500
Engine: 5.7 Hemi
Default
before i got through your entire post i was thinking "motor mounts" to myself.
these get worn out, and any load on the engine seems to "tighten" them up...so the vibration stops. this is why cars/trucks with some miles on them tend to "shake" at idle sometimes.
__________________
2007 Ram 1500 QuadCab 4x4
JBA Stainless Long Tube Headers/True Dual Exhaust
Custom Tune
CAI
Johnnymac2k6 is offline   Reply With Quote
Old 12-10-2016, 11:30 AM   #5 (permalink)
Adam/'s Avatar
Ram Year: 2007
Engine: 5.9
Default
Thanks for the reply Johnny. I suppose now I should give it try to see if it fixes the problem. I suppose what held me up was I noticed the vibration when I first started my truck to drive it away from the transmission shop so i did not want to be spending monies on something if someone had a thought in a different direction. These mounts are not cheap.
This engine is to heavy to lift from the pan to change them and I do have the cross bar to support engines from above but so far can not figure out where to attach it to the engine on the left side of the engine. The right side has the loop to pull the engine to attach to. Any suggestions?
__________________
Old 12-10-2016, 01:44 PM   #6 (permalink)
Engine: 5.7 Hemi
Default
Being you arent pulling it...just holding it in place... maybe a nylon strap around the exhaust manifold and the head. Id probably pull the wheel liners. You'd be surprised what you can get at from the wheel well. Also...cant do it for long being nylon...but maybe you can start it...listen for your vibration...then put some tension on it with the crane. ..see if it goes away. Again..."tightening" the mount if its sloppy
__________________
Custom Tune
CAI
Old 12-11-2016, 11:22 AM   #7 (permalink)
Adam/'s Avatar
Ram Year: 2007
Engine: 5.9
Default
Thanks but there is already a factory bracket to pull the engine on the exhaust side(right) but maybe I can use your suggestion of the nylon strap on the left wrapped around the intake. I think this is just one of those jobs you have to just dig in and figure it out as you go! After I get the mounts replaced I will let you all know if it made a difference or not.
__________________
Old 12-29-2016, 01:18 AM   #8 (permalink)
Adam/'s Avatar
Ram Year: 2007
Engine: 5.9
Default
Well I got it done using the engine cradle for the right side and putting a 2x4 on the lip of the pan and lifting with a floor jack to do the left....scary! Turned out to be pretty easy job, less then 30 min per side. unfortunately it did not help with the vibration at all.....
To top it off now I got another problem which I will start a new post about...
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Engine Vibration at idle desertrogue Engine & Performance 0 07-06-2016 05:10 PM
Vibration 68PowerWagon Heavy Duty 2 05-14-2016 12:41 PM
Steering wheel Vibration in Idle & N Canadian_Ram General Discussions 1 11-08-2015 12:26 AM
Idle problems: vehicle dies when left to idle JimmyDick Engine & Performance 4 10-22-2014 09:53 PM
Rough Idle at Park/Idle in drive Trevorlw Engine & Performance 13 06-12-2014 01:29 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
