who has L.E.D bulbs in tail light
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
I'm looking to replace my stock reverse light bulbs with some brighter L.E.D bulbs. I'm wondering who has done this already and what bulbs did you buy.
EJM05
Somers, CT
440 Big Block
I had them. Loved them. I bought Cree bulbs. But I have 2010
bigbadram1500
Springfield, IL
I have full led tails, but if I were wanting to get led bulbs, I'd go thru retrosolutions.
02blkram47
02blkram47
Lebanon, NH
I have L.E.D tails but only my break lights and signals are l.e.d I have standard bulbs for reverse. Is there a quire to show me which bulbs will fit?
hemi1300
Columbus, Ohio
Not sure what socket type bulb your tail lights take, but these are the one's I bought a while back, pretty sure they'll fit yours toohttp://retro-solutions.net/product-info.php?3156_3056_3157_3057_3457_4157_T20_5W_CREE_LED_Reverse_Wedge_Bulbs-pid704.html. Definitely improved light output behind the truck
bigbadram1500
Springfield, IL
Retrosolutions site has a link to sylvania's site that shows what your stock bulb number is, then you can match it up to retrosolutions led bulbs
02blkram47
02blkram47
Lebanon, NH
Thanks everyone. So when you look at those bulbs its asking to choose a bulb type? Top 5w only and something else? What do I choose?
hemi1300
Columbus, Ohio
Personal preference i guess, i ended up going with the top 5w led only and very happy with them. To my understanding, the second option-radial led-emits light around the sides of the bulb as well? Not too sure on the difference, but either should work
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I would go with the top 5W. The bulb points straight back - that will give you the best bang for your buck.
02blkram47
02blkram47
Lebanon, NH
So Cree bulbs put out more light than the others? Would I need those for reverse lights with a clear case? I found superbright led that seem to be cheaper are they any good?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
CREEs are bright mofos. Most LED bulbs are "bright" but don't throw the light far. the CREEs seem to do a good job with throwing light!
Reverse is up to you, they'll do a good job there too
B-RadsBadRam
Albia Iowa
HEMI
Where does everyone mount their resistors when they use led's in their tails? Gonna get some just curious what everyone does with them. Also any help with which wire to hook them to so I don't have to waste time figuring it out? Does anyone have CREE's in theirs now? Might upgrade to those, dunno
02blkram47
02blkram47
Lebanon, NH
I was under the impression they are just plug and play no need to have a resistor. correct me if I'm wrong.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
For running turns and brakes I believe you need the resistors, but for reverse you do not.
I have LEDs in my tails, just cheapos off ebay, but I am looking at upgrading them all around.
ChloeBrooks
