Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Lowered
Lowered
From 2/4.5 to 4/6 drop
This is a discussion on From 2/4.5 to 4/6 drop within the Lowered forums, part of the 3rd Gen : 2002 - 2008 category!
I have been throwing around the idea of dropping the Ram another 2". Right now for the front I have ...
Like Tree7Likes
Reply
Old 08-02-2016, 01:31 AM   #1 (permalink)
badblackram06's Avatar
Ram Year: 2006
Engine: 4.7
Default From 2/4.5 to 4/6 drop
I have been throwing around the idea of dropping the Ram another 2". Right now for the front I have Mcgaughys drop spindles installed but I also have the drop springs in my shop. I had them installed at one time but the alignment shop I took it to could not align the front end up 100% (uh what?!). After I noticed the inside of the tires wearing after 3 months, I bought the spindles and just swapped the 2 components. After years of thinking about it I want to go ahead and go 4/6. I am just unsure what I need to do to run this setup and it align correctly and the tires clear ok.
Im on stock 20s and 285/50 nittos. I almost positive Ill have to run different size tires. But havent looked into what sizes will fit.
What are you guys running to clear and get a good alignment?
Sent from my SM-G925R7 using Tapatalk
Sponsored Ad
Register to remove this ad.
__________________
Mcgaughy's 2/4.5 drop kit, 72MM F&B TB, Nitto 420s rubber, APM ram air hood, APM ram air intake, Gibson SS ceramic shorty headers, no cats, custom y pipe, magnaflow miffler, 4.56 gears, Diablo Sport Trinity hemifever tune
badblackram06 is offline   Reply With Quote
Old 08-02-2016, 06:50 AM   #2 (permalink)
green97nissan's Avatar
Ram Year: 2005
Engine: 5.7 hemi
Default
275/45/20 all the way around..loaded down my rear tires rub the fender. im sure you could roll the lip or trim it but i didnt want to cuz im narrowing the rear end and bagging it.
and also they had to add the "camber kit" to get the front in alignment. mines mcgaughys 4/6 with coils and spindles.
jotin likes this.
green97nissan is offline   Reply With Quote
Old 08-02-2016, 12:13 PM   #3 (permalink)
ST-8's Avatar
Ram Year: 2004
Engine: 5.7
Default
I have a mc.gaughys 4/6 kit with notch mc.gaughys drop shackelS an trimmed coils up front for a 5/7-7.5 drop. I have a 275/60/17 tire an when it squats it rubs the rear as stated above. My alignment isn't perfect but it's not to bad
jotin likes this.
__________________
2004 Dodge Ram 1500 ST- 5.7L RCSB
SC 3865- Comp 260- 6.1 springs- 6.1 pushrods- Pacesetter coated LT's an Y pipe- magnaflow 14" dumped- egr delete- bfi #42- 4.56s- oem lsd unit- junkyard 4.7 trans an converter- healthy 5/7 Mc. Gaughys- off road 17s on 275/60 nitto 420s
ST-8 is offline   Reply With Quote
Old 08-02-2016, 12:25 PM   #4 (permalink)
jotin's Avatar
Ram Year: 2003
Engine: 5.7
274/40/20 will be your best bet. I second that. My truck is a 3/5 and I'm running 245/45 cause they were free lol
jotin is online now   Reply With Quote
Old 08-02-2016, 06:26 PM   #5 (permalink)
Ram Year: 2004
Engine: 3.7
Default
Mine aligned perfectly with the 4/6 and no camber kit and close enough with 5.5" with no camber kit. All I did was notch the alignment holes a little bit with a file. Took 10 minutes per side while I had the upper control arms off.
I want to go about 1/2" lower on the front, but I'm going to have to do some metalwork under the fender liners to go any lower, there's a nice sharp edge that could contact the tire on a big bump that would need to be reworked. It'll happen eventually, but 5.5 will have to do for now, I want to get the back a bit lower before I dive full force into the front again.
I can't help you on tire sizes, I'm running a 265/35/22 but I think I could have went another size up with no problems with rolled and slightly flared fenders.
jotin likes this.
Bullitt5339 is offline   Reply With Quote
Old 08-02-2016, 07:19 PM   #6 (permalink)
sbarron's Avatar
Ram Year: 2013
Engine: 5.7 HEMI
Default
Bullitt5339, that truck would be worthless where I live but man oh man is it sexy!!! Well done sir!
Bullitt5339 and jotin like this.
sbarron is offline   Reply With Quote
Old 08-02-2016, 07:36 PM   #7 (permalink)
Ram Year: 2004
Engine: 3.7
Default
It's not as bad as it appears. It has more ground clearance still than my stock daily driven car and it has helper bags in the rear so I still use it to haul my Mustang on the trailer and still use it as a truck.
The only worry for me is hitting a sharp edged pothole and destroying a wheel because of the lack of sidewall.
Old 08-03-2016, 06:31 AM   #8 (permalink)
Ram Year: 2005
Engine: 5.7 hemi
Default
if iwas to keep the 4/6 drop and not bag mine..id add helper bags and run the 275/45/20sas long as i kept 20s. ive hit some messed up pot holes and lots of back road stuff and the 45 series has held up. wouldnt go less with a 4/6 drop IMO too much gap from lack of tire with 40series when a 45 works perfect
Old 08-03-2016, 09:15 AM   #9 (permalink)
Ram Year: 2006
Engine: 4.7
Default
Awesome trucks guys. Thanks for the help. I started on the front this morning and have the drop springs in. Just need to finish up this evening when I get in from work. It wont be going anywhere until I get those tires and c notch in. My 06 has the lower control arm camber adjustment but im sure I'll need to do some slotting on the uppers. We will see though.
__________________
Old 08-03-2016, 09:37 AM   #10 (permalink)
Ram Year: 2004
Engine: 3.7
Default
I'm having relocated upper control arm mounts from Michigan Metal Works installed in mine. I was going to put their camber cure upper control arms but after talking to them I changed my mind. The camber cures fix the camber, but they don't fix the geometry issues after lowering. The relocated uppers fix both, they're less money to buy, but more to have welded in.
I plan on bagging mine in a couple years as well and the relocated uppers can be used after changing up, the camber control uppers can't be.
Now that I'm lowered, I'm trying to get the suspension geometry back into check.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2-4 drop? rammanriley20 Lowered 4 07-28-2015 11:23 PM
using drop springs and drop spindles delunad Lowered 11 05-06-2015 11:01 PM
1995 ram 2/4 drop going for a 5/8 or 6/9 drop johnmarks Lowered 4 04-29-2014 12:53 PM
Best kit for 2/4 drop ShortBed Lowered 12 09-10-2013 07:12 AM
2" drop shackles show no drop?!? Tripp12345 Lowered 11 06-11-2013 08:05 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
