Few drop qs
usaf2006
Augusta, GA
Currently my rear is 3.5" higher than my front...lol... any way I could do a 4.5" drop in the back and just 1" up front for level? Is just one inch up front possible?
If not can you find the drop spindles (4wd truck, spindles the only way?) Under $400+? Id be doing a flip kit in the rear as well that way.
Regarding a flip kit. How big of an issue is pinion angle. Id be okay doing it myself and getting the perches welded if I knew that if the pinion angle was close enough, that my rear end wouldnt blow up.
redsled
Socal
I would just look at McGaughy's and buy a kit. I have learned in the past not to piece things together, to many little things can be forgotten.
Navarabr
Im at a 4/6 on my 05 Ram, with Spindles, and Cut Springs for now for the front, and a flip kit on the back. I bought my spindles for 420 online, thats the cheapest i found.
Or you can just buy a KIT like Redsled said.
Goodie1990
