2" Leveling Kit and Tire Clearance
amenges
Massillon, OH
I have a 2" leveling kit on my 08 RAM 1500. stock tire size is 275/60/20. Would I have a clearance issue running 305/60/20? The 305 are almost the same price as the 275, where as if I go with 285 they are like 500 more!
NWRQC
Height wise you will be fine, but you might need to run a small 1/4" spacer for clearance width wise.
quietpeen
2021 TRX
Hellcat
If your truck is 4x4, then what nwrqc is correct in it rubbing and needed a 1/4" spacer
A
amenges
Massillon, OH
Where can I find a 1/4" spacer? or even a 1/2" I've looked at a lot of places with not much luck. For a 08 Ram QC 5.7 4x4
This is all that I found:
Spacers
Screw the 305 idea. I'm looking at the Nitto Terra Grapplers and they have a 295/60/20. Would I still have clearance issues if I didn't get the spacer?
Vendor
Florissant, MO
2x 5.7L & 6.2L
I got some 1/4s - got a set from Amazon and eBay. I have an extra set here now. LOL whoops.
A
amenges
Massillon, OH
So with this Spacer I can run 305/60/20? And the tires will stick out from the truck however thick the spacer is?
So by getting these Fender Flares it won't be as noticeable sticking out?
quietpeen
2021 TRX
Hellcat
Yea with a 1/4" spacer you can run those tires. They won't stick out that far
Grubrunner
Those fender flares painted would look awesome!
That's actually a sharp looking Ram.
ram e'm
I have a 2002 ram quad cab 1500 4.7
I want to level my truck to the same height as the rear. I want to know what size spacer for the front coils i should get to make the truck level.
Herefishy
