coil spacer lifts
FloridaDodge67
Jacksonville, Florida
3.7 v6
i want to know if a 3 inch coil spacer is a good idea cause i have heard they might cause vibrations and put stress on my lower control arm and ball joints
so should i get a 3 inch coil spacer or stick to the 2 inch one
ramhunter9
P-Star Jeep Wrangler
Rule of thumb.
Anything over 3 inch or more you will need more suspension upgrades.
2 inch you will be fine
Stangshcky12
Oshkosh, WI
5.9 Cummins
Im assuming your truck is a 2wd? Alot of people run 3" on 2wd without problems but its really pushing the limits of the ball joints
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
This site use to carry the spacers I have. They are daystar 2.5" spacers. But this kit should work be good.
http://performancelifts.com/cgi-bin/cart/CSCDX2.html
Droid Incredible 2 on the move!!!
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Did you put that on top of your rcx 6" ??
Yes I did. Made the ride imo better. Before it was bouncy lol. It worked out great on mine, and Weedahoe's lifts. I haven't had any pro oem with it wearing out parts. And my upper control arms don't hit. But I think it is only accomplishable with the 6"
ChloeBrooks
