Torsion keys
badfish888
Va beach
2012 hemi express
Who here has after market torsion keys? is it worth it to buy them or just as good to crank the factory ones. Good brands? bad ones? Been looking to get rid of the factory rake.
HKkid
Missouri
I cranked my stockers. Its level and been that way for well over a year now.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I had torsion keys from skyjacker on my 04, just cranked my wifes 05. I vote cranking the bars and replaceind the shocks with the 100 you save not buying the new keys.
ramhunter9
P-Star Jeep Wrangler
and the hundred saved from the keys put it toward longer shocks
cheapbeater
Wisconsin
no need for aftermarket keys... they do the same damn thing as the stockers.. you can go higher with lift keys, but then your cv angles are hideous
quietpeen
2021 TRX
Hellcat
if you have enough adjustment with your stock keys no need for aftermarket. Mine i was only able to go 3-1/4 turns which didn't level it but raised the front enough that it looked much better.
badfish888
badfish888
Va beach
2012 hemi express
When i do crank them, should i and it is a good idead to crank them all the way and max out the keys? Or try to leave some adjustment and make sure bolth sides ar even? Will i need an alignment afterwards? And so i buy shocks for a 2 in lift?
quietpeen
2021 TRX
Hellcat
i would only crank them as far as it takes to level the truck. You definitely want to have both sides even. Yes you will to have an alignment done after you crank them.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Put the front of the truck on jack stands and turn the bolts 3-4 complete turns and put the truck back on the ground. Put the truck in reveres and move it back a few feet, then back foward a few and then measure. You have to do that to let the sys settle and sit right. Normaly the drivers side will take a quarter or half more turns. Soak the adjustting bolts before you do it and get a socket and mark a line on it for reference.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Start with 3 and see where your at. To measure and make sure the truck is level from side to side I measured from top of the tire dead center to the bottom of the fender and that will be the easiest way.
badfish888
badfish888
Va beach
2012 hemi express
sweet, this will save me some cash for shocks, but when i order shocks do i need shocks for a 2 in lifted front?
badfish888
badfish888
Va beach
2012 hemi express
oh, and is it ok to lets say, Crank them up tonight to see if i like the look, maybe even drive a few miles w/o a alignment or is that a bigg no no? dont wanna eff up my tires? Or if i dont like the look and i put the keys back to there original position, it should re alignt everything...rite?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Yeah long as you write down the amount of turns and return it back you should be ok. Depending on if you hit a bump tonight or not you might hear and feel the shock fully extend and stop. You should put new front shocks on if you decide to keep it up which you will prob like. If you still have the oem ones from the factory then get a whole new set front and back.
badfish888
badfish888
Va beach
2012 hemi express
ok, but when i buy new shocks, do i buy the factory spec ones or ones for a 2" lifted truck
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
This is the set up on my truck and ride great. I got all this at shockwarehouse.
2)F4-BE5-6248-H5.... These are Bilstein 5100 offroad racing units
2)F4-BE5-6243-H5.... These are Bilstein 5100 offroad racing units
6)98108G.... These are Bilstein bushing 3/4 urethane eyelet
6)423730.... These are Bilstein sleeve 20x14.4x42.4
