06-08 sports bumper conversion
The Assassin
B-more careful, Murderland
So, I have tried to do some digging and I just wanna make sure I have this right. For the 06-08, all I need is the bumper cover, and the sport beam, is that correct?
Anyone on here actually done this?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I did it in my dreams last night.
Oh wait..........we're talking about bumper swaps.......nevermind.
:D
look at page 339:
Parts list biotch
All the part numbers you would want. :D
lilfroger
5.9 CTD
Yup just the cover. The switch I did was from an 07 1500 to an 06 3500
The newer smaller rig had a different mounting plate than the CTD:
06 3500's mounting plate:
Brackets come off w/ a couple bolts and the cover can be swapped:
Back bumper lines up just fine.
Sorry it wasn't a fully DIY the project got started while I was @ work and finished in a hurry due to a family emergency.
RubberFrog
Frogger, what did you do in those pics? It just looks like you swapped a painted bumper for a chrome one?
OklaHemi
new age hemi
a st for and slt
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
little different than a chrome to sport swap though.......
lilfroger
5.9 CTD
OK :) Thought they were the same mounting bracket
OklaHemi
new age hemi
no mamm the sport bumper have a couple more pieces to track down
Silverbullet08
Persona Non Grata
yea it does
These are all quotes from "Workin". Apparently its an easy mod on the 06-08 models. The Sport or Laramie cover basically slides right over with no issues.
Quote:
Originally Posted by Workin
If you have an 06 ram, you can slide a sport bumber cover over the stock slt chrome bumber...you will only need remove the upper half. you will need to use a billet grille in the lower opening to hide the curved edges, or just cut it out larger. if you need pics of mine, just holler..........
your right.. this has been covered before.
a sport bumber skin will go over the stock chrome bumber, with ( no modifications ). simply remove the top half of the old bumber.
the only thing that will show is the rounded ends on the smaller grille opening, and if you use a billet insert there, it will never show.
sport bumbers are on ebay all the time.............
yes, and it will fit directly over your exisiting chrome bumber, there is another thread on this somewhere.... you better jump on that price as well........mine was applied over the stock slt bumper
Quote:
Originally Posted by Working
yes... remove the upper assy, remove fog bezels, remove the upper rubber in the center, remove the very outer bumper bolts for reuse...you will have a lower second outer bumper bolt hole in the sport bumper, but you will not need this to hold the sport bumper on......
The Assassin
The Assassin
Found all the part numbers. This is from diesel truck source.
Alright, here we go...
Beam.................55077960 AC
Fascia................68001358 AA
Step pad............55077763 AB
Air dam..............55077971 AA
Chrome center.....55077774 AA
Retainers (4).......6502625
Upper bracket......55077374 AD
Upper bracket......55077375 AD
