how to remove plastic chrome door handles
big_red06
2014 Bighorn
I would like to remove the plastic handles which still look good from far away but up close are starting to get alot scratches on them and install some stainless steel ones i found on ebay how do i get them off without messing up my door handles also will i run into the same problem with the stainless handles and scratching thanks all
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
There are bolts in them, nuts hold them on from behind the door panel. pretty easy, I had mine out when I did my jimmy jammers.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Don't know about 4th Gens but assume 06 to 08 must be like the earlier Models and only come in black. If they are stick on Chrome handles like available for 02-05 Factory Black handles then they are on with strips of 3M, a Hair Dryer or heat gun and some paitience will allow there removal but carful not to burn your fingers on the 3m glue getting that off too.
