03Blackride
- Jul 16, 2012
- 56
- 0
- 2003 Dodge Ram 1500
- 5.7L Hemi
I just replaced all the spark plugs on my 2003 Dodge Ram 1500 Hemi 5.7 engine, and it still barely idles on it's own at 600 rpm. To keep the engine from dying, I need to constantly press on the gas pedal to raise the rpm, if not it drops to 600 rpm immediately. I installed Champion 3570 Platinum Power plugs. The PCM is not throwing any codes. This makes things really difficult to troubleshoot. I did a scan using my OTC Genisys Scanner with the key on, and the engine off. Here are the results. I hope someone can understand it:
2003 Dodge Ram 1500 Hemi Engine Troubleshooting
Using my OTC Genisys Scanner
Key On Engine Off
Engine coolant temp - 3.13 volts
Engine coolant temp - 95 degrees
Intake air temp - 3.34 volts
Intake air temp - 86 degrees
APP Sen 1v - 0.43 volts (no change when the gas pedal was depressed)
APP Sen 2v - 0.24 volts (no change when the gas pedal was depressed)
Accelerator pedal position (0) (no change when the gas pedal was depressed)
Ambient temp - 1.73 volts
Barometric pressure - 30.53
Cat Modeled Temp - 83 degrees
Cam, Crank Difference - 0.90 degrees
Cam sync at start - In sync
Cam sync state - Out sync
Closed loop timer - (0) usec
Current fuel shutoff - disabled
Elec Throttle Control - (3) (no change when the gas pedal was depressed)
Fuel level percent - 40
Fuel level sensor - 2.24 volts
Injector pulse width cylinder # 1 - 41.36
Map sensor - 4.57 volts
Map vacuum - 0.06 inHg
S/C switch 2 - 4.55 volts
TPS 1 minimum volts - 0.49 (no change when the gas pedal was depressed)
TPS 1 volts - 0.86
TPS 2 minimum volts - 4.56
TPS 2 volts - 4.16 (Looks like this may be a problem)
Target idle speed - 12800
Voltage sense - 172.00 volts
Well according to my OTC scanner, the TPS 2 volts at 4.16 appears low. The minimum volts should be above 4.56 volts. My question is: Where and what is the TPS 2. With the key on engine off, when I press on the gas pedal, shouldn't the voltage value change. There is no change when I press on the gas pedal slowly to the floor, then back off on the gas pedal slowly all the way out. Any help will be greatly appreciated. Thank you, Tommy.
Key On Engine Off
TPS 1 volts - 0.86
