KGBIGCOUNTRY
- Jun 29, 2010
- 13,309
- 475
- Location
- MECH, VA
- 2004 RCSB/2005 QCSB
- 5.7 / 5.7
If your concerened about the valve being damaged I would pull the head just to have the ease of mind to inspect both the valve and the piston face. Your just about there with the vlave cover off. Only things left would be unplug the main harness at the back of the intake manifold and unbolt that. Unbolt the 2 bolts holding the exhaust manifold to the down pipe. Undo the bolt on the back side of the head for the ground strap. Last should just be unbolting the head and lifting that out with the exhaust still bolted to the head. If it will seal with air the valve is good.
