3rd Gen Catch Can?
PCA4208
Albuquerque, New Mexico
Is it possible? I already just have a breather filter on the oil fill breather. But I'm talking about the whole PCV deal. Has there been any Custom fabs? I'm asking because I cleaned my throttle body a while back, and when I put in my plugs I noticed it was just filthy! Also I might be putting a tuner soon, and I want to get the most out of it.
My humble setup
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
Yeah i think the source URL is blacklisted or you have to be a member of it.
Sent from my ASUS Transformer Pad TF700T using Tapatalk 2
TheSatinPumpkin
2004 Dodge Ram
5.7L
Should see it now
PCA4208
PCA4208
Oh ya that's clear now. I don't think I'd need that much elaboration. I think maybe I can figure something out.
Stangshcky12
Oshkosh, WI
5.9 Cummins
3rd gens have an internal PCV
There is a hose that you can run a catch can on the goes back to the intake I believe but you won't catch nearly as much oil
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
You have the engine ventrd from the fill tube, If you don't have residue on the filter then then oil is being controlled. It's the inlet side of the PCV anyway. As for your TB getting dirty maybe check your air filter. I use a tooth brush and brake cleaner with the TB removed to clean mine.
Killavolt
Ontario
Only one i have seen on a 3G is otter1363
I can't believe that someone would go to all that trouble and expense on a motor, and not even realize the catch can is hooked up backwards and not even doing anything.
thats the air INLET for the PCV system, it's sucking air IN through that oil fill tube so it gets filtered air from the intake.
HemiLonestar
Navy Badge Coast Guard
MD
Really? 7yrs later? Twice?
^^I cant believe someone just replied to a 7 year old thread lmao.
Believe it, did it twice lol: https://www.ramforum.com/threads/pacesetter-headers.39342/page-2
Happens all the time, people find something and either they're totally lost and don't look at the date or they have a strong opinion about the subject and absolutely must comment on it.......the worst I've seen is 15 so far lol. I mean, I guess we should be happy they're using the search bar lol?
Marley
VA
Hmmm was following the thread with great interest then deflated.
By the way, sometimes physical appearance trumps functionality. Lol
