4.7l throttle position sensor
badblackram06
MS
Alright I have noticed lately on my diablo sport trinity that my throttle position is only reaching 60% even though the blade is fully open. With that said I am also noticing that my truck is no longer kicking down a gear at 65mph. So I tested the sensor using my DVM. The sensor has 5volts going in. Closed voltage was .38v. Fully open was 3.48v. Does that sound right? I am not experiencing idle issues or anything just the transmission not kicking down at 65mph. Bad sensor maybe?
HemiBabe
DFW
Hopefully someone will chime in shortly
badblackram06
badblackram06
MS
Well I'm getting idle surges and high idles now.
Sent from my iPhone using Tapatalk - now Free
badblackram06
badblackram06
MS
It seems to be getting worse. Do you guys suggest a oem one over a retail parts store brand. I called the dealer today and of course they didn't have one but if it matters I can wait.
btah
And the results are?
badblackram06
badblackram06
MS
No more idle surging but the trinity is still showing that the throttle position percent is 60% at WOT. I quit worrying about it since the idle returned to normal.
hemihustlin
Montreal
Even though i believe the the TB is cable driven on the 4.7s (correct me if im wrong) but is there not a relearn procedure?
badblackram06
badblackram06
MS
I had looked that up but didn't find anything. There were no instructions to do so with the new sensor. I attempted the procedure like on the Hemi's but it didn't do anything.
mudmole1
unplug the battery for 10 min for the pcm to relearn
Goodie1990
