gonna start ordering exhaustparts!
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
I have no idea what they're worth. But here they are.
truckin151
2013 sport
yea my exhaust shop has the tool to widen it out. ill be going on friday to get my quote.
You cant widen the pipe, you have to cut it open to a 3" in/out, otherwise its a 2.5" in/out pipe so you'll go from free flowing to restrictive to back to free flowing.
Stock cats online new go for around $80-$90 per cat, used probably cut that number in half as long as they were still working when you used them last.
truckin151
2013 sport
is that an O2 sensor port on the top of the cat? If so that is different from what the 05's have, they have the **** behind the cat, only hole in the cat is a small drainage hole (make sure when you install them that that is pointing to the ground or they'll rust). Not sure if the PCM will read right if it is taking the reading from inside the cat though since ours is designed to read from before and behind the cat.
05singlecabHEMI
05singlecabHEMI
Lilburn,GA
Damn. i think me and my exhaust guy will figure every little bit out. And i already bought somthing today, saw a good opportunity on this and wasnt expecting to buy it for a while. Guess yall will see it when i see itt
ill just have to keep looking out for the cats. Or ill sit there for an hour cleaning it...
Wise words from Nick " Clean your exhaust after muddin!!"
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Keep us in the loop cant wait to see what you get put on.
TMFMK
