Snackcake 01
- Aug 6, 2017
- 11
- 2
- 2006
- 4.7
So the story on the truck... 2006 1500 QC 2wd with the 4.7. bought it off a friend who manages to have a slight engine fire. I had to replace the intake manifold, throttle body, engine harness, , front section of the fuel line,body harness, tipcm, and alternator. Will turn over and try to crank but the injectors aren't pulsing. Getting solid fuel pressure that is at 56-58psi. Before I replaced the front section of the fuel line it would actually fire up and die immediately because the line kept popping off the rail because the quick disconnect was messed up. Replaced the line and now it holds fine but the injectors aren't pulsing. I replaced the crank sensor,cam sensor, and ignition control switch on the steering column by the steering wheel. What else would affect the injector pulse? Anything around the fuel line that I may of jarred loose or something? Starts up and dies immediately with starting fluid. So I know it's got spark and good pressure on the rail. Pulled the plugs and they were bone dry. After turning over that many times figured it would of flooded or something but the injectors aren't spraying. Any ideas? Been searching for a while and can't find anything on it except what I replaced
