Thats the front cover oil seal im willing to bet. Easiest way to do it is going to be basically the same starting process as a cam swap. Pull out the rad, trans cooler ect so you can step into the front on the engine bay. Your gonna need to pull the belt and crank pulley and decide if you want to pull the seal from the front, or take off the timing cover and replace it that way.
