2005 1500 w/ 5.7L Hemi
Hey all. Hope I can get to get some help with a problem I've been trying to work through for a couple months now. When I start the truck the engine runs smooth when in either Park or Neutral but when in Drive the idle becomes rough and verges on stalling. As well, the engine hesitates on acceleration. Though typically the engine evens out a bit when up to constant speed ( highway ) there are times when its in a bad way when I have to stop the truck because of surging/hesitation. I also get engine codes. I always get a P300 code (Random cylinder misfire) and depending on the day various others including P0175 (System too Rich) or P0151 (O2 sensor low voltage). I even get the occasional backfire pop. Things I have done include removing and completely cleaning out the throttle body and replacing the air flow and MAP sensors.
With all the above being said there are other interesting facts which lead me to believe it may be electrical in some way.
When I disconnect the battery for 10 minutes and reconnect, the truck runs great - no rough idle or acceleration issues. And then after a week or two the above the rough idling/acceleration/codes return. At first I thought it was because each one of the solutions (cleaning throttle body, installing new sensors) fixed the problem but I now know that is incorrect. The fact is that I unhooked the battery in each case and THAT was why the truck ran better for a while. So I have been disconnecting/reconnecting the battery every couple weeks to get the truck to run right.
My guess is that it is electrical in some way but I'm not sure where to go from here. Somehow disconnecting/reconnecting the battery clears something out but over time whatever was cleared out gets fouled and the truck returns to running like crap.
Any help appreciated! THANKS!
