throttle body cleaning
no name
Socialist Republic of Illinois
I have searched but still havn't figured it out. What do you use to clean it? I have read carb cleaner and brake cleaner. Some say don't use carb cleaner. Isn't carb and brake cleaner basically the same stuff? Also read to use Sea Foam Deep Creep. Any help would be greatly appreciated. Did I miss a DIY on this?
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
Brake cleaner is best. Just soak it down (be careful not to hit the electronics on the butterfly valve). Most should fall off with just spraying it. You can use your wife's toothbrush to get the rest out, or just wipe it out
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Ditto, service manual specifically states "do not use Carb cleaner" as it may damage the electronics.
bigtigga84
dela....where?
I was wondering about this myself. Can the electronics be removed for cleaning?
AF_Hemi
theres no reason to remove the electronics. Brake cleaner wont hurt them as long as its not sprayed directly onto them. Removing electronics would be a big waste of time
AJMAG
new jersey
i just cleaned mine yesterday with brake/contact cleaner that i use on dirtbikes and worked like a charm, and damnn was it dirty. much better throttle responce!
HemiBabe
DFW
Really??? I was wonderin if you could notice a difference or not, I guess I'll do mine too!
N
no name
It's done. Pretty easy job. Maybe I will gain a few mpg's now. Throttle response seems better and seems to have woke up a few more ponies.
rocket
Licensed Dynacologist
connecticut
was 2006
was a HEMI 5.7
I soaked mine in palmolive, it's not very clean but madge likes it...................nothing? It was an old commercial.....figures.lol.
bigbadram1500
Springfield, IL
Brake cleaner is what the hubby always used. Never cleaned mine yet. Might have to try it out. Truck's got almost 40k, tb is probably dirty.
