redram2007
- Sep 29, 2012
- 1,092
- 60
- Colorado Springs (Ft Carson)
- 2007
- 4.7
I just ordered an Autometer 4379 AFR Gauge to aid in tuning and i have a question about installing the 02 sensor and a wiring question. I know i need to drill a hole and weld the **** in before the cat. My concerns are when drilling the hole w/o removing the cat how do you prevent metal shavings from going into the cat and will the small pieces of metal hurt anything? Also in the directions it calls for 2 12v sources. The brown wire (heater override) is optional but should i connect it to a switch or another keyed 12v source? Just a little confused on these two things. Once i get some insight on this and recieve my gauge i will post my DIY with pics.
http://static.summitracing.com/global/images/instructions/atm-4379.pdf
