Tinsey
I have tapped into the rear 12v switched outlet to supply the relay for air horns. Blown fuses. Maybe my wiring is wrong but I am asking for an easy access switched 12v to supply only the air horn solenoid horn switch. I will leave the relay for compressor tapped into the rear 12v power outlet. This way I will have two separate supply's. One for compressor and one for the horn switch.
Thanks
Thanks
