I'm installing a amp in my 17 ram. I do not have the alpine system. Where can I tap into for a remote wire and what color speaker wires are the rear driver side door ?
Search around on the forum there are many wire diagrams for the speaker wires. Some would go to the head unit, some would go to the door jams.
As for a remote wire you can use the cig lighter or use a fuse tap and go to the fuse box. Either way ONLY use it as a trigger for a relay. These trucks are sensitive to current draw and draws on different systems can cause CELs to turn on.
What do you mean only use it as a trigger for a relay?
