[email protected]
- Aug 24, 2014
- 55
- 9
- 13 Ram 1500 5.7 hemi
- SLT Outdoorsman
2013 ram 1500 outdoorsman
Just replaced hi, lo and fogs with Sylvania zxe bulbs. Cut tabs out of bulb to get 9005s in fogs, 2 minutes.
I ordered a kit from me. Tail light which is supposed to keep fogs on when i switch hi beams on. It looks really easy, I think it will be easy, but wondering wether dealer can just change this setting in trucks software. Seems silly to turn off fogs with high beams, In fact not sure why the Lo beams have to turn off. I know the are not gonna make a big difference, and will probable burn out in less then the 1 yr warranty period. Definitely way brighter and whiter then stock bulbs. So the question I have is simple, will or can dealer make all lights stay on when I switch to high beams, or at least highs and fogs ?
Since the mr. Taillights kit seams to be feeding fogs power from high beam positive, why not just run same feed to lows as well. So whenever highs are on, lows get juice too?
You can probable tell, I suck at wiring.
