HID = Fuzzy Radio, help anyone?
mxblaster83
British Columbia, Canada
2014 Ram Sport
HEMI 5.7
i installed a set of hids awhile ago and i always listened to SAT, i cancelled the sat and now my local radio stations suck, really bad fuzz and static,
i have already tried wrapping the ballast in tin foil,
any other ideas?
MADDOG
Out Exploring Arizona
Are they digital ballasts?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
doesnt sound like they are shielded too well. Might try to move them to a different mounting location, might help?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
badblackram06
MS
I had this issue once. I dealt with it for a while then decided to go 6,000k from 10,000k and the static was 95% gone. Same ballast different bulbs. Is it possible the bulbs also cause the static?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
i can't see how.........
badblackram06
MS
Me either but it was an odd thing. I'm glad it cleared up. I've heard a possible fix for the static is "ferrite beads" at the cable coming out of the ballast going to the bulb.. They help filter the RF. I was going to try them but I no longer needed them.
MADDOG
One way to eliminate RF from an electrical source is to install an RFI filter at the radio end of the antenna.
LB3711
Trumbull, CT
3.6L V6
Mine does static too on FM not sure if AM would do it too. I just don't listen to regular radio much anyway.
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
i wrapped them in tin foil and remounted them and still static.
i dunno what to do. if anyone has been to vancouver before they might know 99.3 the fox. well i miss it, but looks like i might have to reorder SAT again:(
