All I got..
12volts red (40A) + BCM under driver dash, black 4 pin plug (B), pin 3
Starter lt. blue/tan + BCM under driver dash, black 24 pin plug (A), pin 19
Second Starter purple/brown Ignition Node/Keyless Ignition Node Module, blk 6 pin plg, pin 4
Ignition pink/white + BCM under driver dash, black 48 pin plug (E), pin 27
Second Ignition brown + BCM under driver dash, black 24 pin plug (A), pin 18
Third Ignition N/A
Accessory brown/orange + BCM under driver dash, black 48 pin plug (E), pin 36
Second Accessory N/A
Keysense N/A
Power Lock purple/lt. green (passenger door switch) - 330 ohms Passenger Door Module, black 10 pin plug, pin 4
Power Unlock (same as power lock) - 100 ohms
Lock Motor lt. green/dk. blue 5 wire BCM under driver dash, white 48 pin plug (F), pin 2
Unlock Motor tan/lt. green 5 wire BCM under driver dash, white 48 pin plug (F), pin 1
Parking Lights+ white/brown (LF); white/orange (RF) + BCM, black 24 pin plug (A), pin 4; white 24 pin plug (D), pin 3
Notes: The LR - RR are white/gray - white/orange (+) at the BCM under driver dash, white 48 pin plug (F), pin 32; black 48 pin plug (E), pin 4.
Parking Lights- white/brown (need to relay isolate the switch) -1130 ohms BCM under driver dash, blue 24 pin plug (G), pin 20
Hazards white/dk. blue - BCM under driver dash, blue 24 pin plug (G), pin 21
Turn Signal(L) white/lt. green (F); white (R) + BCM, white 24 pin plug (D), pin 14; white 48 pin plug (F), pin 40
Turn Signal(R) white/tan (F); white/lt. green (R) + BCM, black 24 pin plug (A), pin 13; black 48 pin plug (E), pin 2
Reverse Light white/tan + BCM under driver dash, white 48 pin plug (F), pin 41
Door Trigger purple - BCM under driver dash, white 48 pin plug (F), pin 9
Dome Supervision yellow/purple + BCM under driver dash, blue 24 pin plug (G), pin 14
Trunk/Hatch Pin N/A
Hood Pin purple/lt. blue - BCM under driver dash, black 24 pin plug (A), pin 11
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm (arms on lock with door open)
Factory Alarm Disarm (see disarm no unlock)
Disarm No Unlock (transponder and ignition)
Tachometer brown/stripe ac any fuel injector
Notes: On diesel models, use dk. blue/gray at the camshaft position sensor, 3 pin plug, pin 3.
Wait to start N/A
Brake Wire dk. green/white + BCM under driver dash, white 24 pin plug (D), pin 18
Parking Brake dk. green/white - BCM under driver dash, black 48 pin plug (E), pin 11
Horn Trigger dk. green/white + BCM under driver dash, black 24 pin plug (A), pin 23
Memory Seat 1 purple/brown - resistor memory seat switch, black 4 pin plug, pin 3
Memory Seat 2 (same as memory seat 1) - resistor
Memory Seat 3 N/A - resistor
