hugecanoli
- Mar 25, 2016
- 2
- 0
- 2011
- Hemi
Hi Everyone...been lurking for a while and have learned a lot about my truck over the years from you guys.
I have a 2011 Big Horn and I did something stupid today. I read a post here about replacing the dome light with a little LED board and ordered it from Amazon. (https://goo.gl/zdx1Eb) It came with the bulb adapter and was working fine when i opened and closed the door but did not go on when manually pushing the bulb cover button.
While fiddling with it, I think I may have crossed both the ground and hot on the bulb holder. I put the reg bulb back in and it works when the door is opened and turns off after a while once door is closed. But the manual button does not work and now my map lights, glove box light or visor vanity lights will not go on when I manually try to turn them on.
I've been reading that this could be a IOD fuse problem but I cant find a picture or an exact location of where this is located.
Any help is appreciated as I'm trying to just get this back to how it was working before I tried installing the LED.
Thanks!
Thanks!
