Masterglitch97
- Feb 4, 2017
- 6
- 0
- 2016
- Hemi 5.7
So recently purchased a 2016 Dodge Ram 1500 big horn with the uConnect radio. I am an avid audio person and am in the process of upgrading the stereo in the car. In the process of adding a component set of speakers to the doors. I have some how lost all signal to just the driver do. It's the first door I've started in and I set up everything temporarily as to make sure it work. It's the speaker wires going to a crossover. From there to a mid bass driver and 2" tweater. Now when I first set this up everything worked great. No problems. I went and installed everything and went to put the door back together. And no sound. I tested the speaker wiring with the stock speaker and again no sound. I'm lost as to what has happened. All other doors still play normally. I'm afraid to move forward in fear I may cause more problems. Has anyone every had this issues before. How can I fix it. If possible or how can I prevent this from happineing again. So far my plan is to run an LC7i line out converter behind the dash to run a skar audio 80.4 fort the 2 pairs of components in the doors and then a skar audio 60.4 bridges to run a pair of 3.5" super tweeters in the dash. I also will be running 2 skar audio ZVXv2 15's tuned to 28hz in the back seat. Powered by a D.C. Audio 3.5k at .5ohms.
