so we got my buddies install finished in about a day and a half/2016 RAM Express Reg Cab. New Years Day and some into the 2nd.....I had a amp wiring kit and Audio control LOC on hand to contribute to the build.
Parts we used were an Audio Control LC2i, XSpower amp wiring kit, JBL 5501 amp 2ohm stable, alpine SWS 12" sub (dual 4ohm) wired for a 2ohm load, kicker KS 3.5's in the dash w/800mhz passive xover, and kicker KS 6x9's in the rear cab.....stock door speakers.....oh and a Metra wedge slot ported box w/1cuft airspace......sub requires 1 cuft in a ported box so with the displacement of the sudwoofer the box was slightly undersized.
Sound was/is a dramatic improvement. I believe the little JBL amp pushes 550w RMS.....with a little tuning she sounds VERY good!
this whole thing started as a dual kicker hideaway install, but with a botched online order w/ 2day delivery it turned into a Best Buy run/thrash session.
My buddy is VERY happy with the results; we ended up taking the seats/jump seat out and center console.....rear storage tray.....door sill panels and lower B pillar panels.....and the carpet.
We took a piece of 3/4" MDF and made a mounting plate to fit under the driver's seat, transferred the pattern to the underside of the carpet and removed the foam padding on that area for a flush fit, we hot glued the MDF to the floor of the cab, re-installed the carpet so no screws went through any metal.
we took the time to route all wiring cleanly and (fingers crossed) in such a way we didn't pick upo any noise......we succeeded!
we took the speaker inputs and from behind the Head Unit and continued with twisted wire we turned with a drill motor to complete what the factory had done.
That's about it....like I said.....it was sort of a thrash and a plan based on available parts but it actually turned out rather great!
Now I need to get ma'butt in gear and get my install done thats been sitting in my closet for almost 2 years now! lol
