MyGig problem
Rcobb887
Savannah, GA
Just installed the mygig on my truck. Video works fine, all the new options are up on the screen, but somethings up with my audio. I double checked and I did not find a loose connection. It sounds like its at half power almost like when something is partially unplugged. Frustrated. Any suggestions?
Musclemckeester
Houston, TX
n/a
n/a
Did you make sure all the pins line up? I had an issue with mine when I installed the LockPick. It was really strange and an intermittent problem but ended up being a pin was slightly bent. Bent it back in place and all has been fine since.
quietpeen
2021 TRX
Hellcat
See if there is an update for the software. This sounds familiar and I think the update might have fixed it
Rcobb887
Rcobb887
Savannah, GA
Yeah after I posted that question I went and checked the pins. Found three in the gray connector bent. Had to bend them back three times before they would go in straight. Cheap materials I'm guessing. Because I couldn't connect the male and female any straighter than i was doing it
Rcobb887
Rcobb887
Savannah, GA
I knew it was a power issue. Things always seem more difficult when ur frustrated. Sometimes you just have to walk away for a second lol
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
glad to see that you got it fixed!
Herefishy
