Ra1 to ra2 camera rerout
noclass
Ra1 to ra2 camera reroute
Have an ra1 with backup camera in the mirror and am swapping to ra2. I have to reroute the camera signal to the radio someone use to make a harness any one know where to find it it's just 3 wires. I could buy the mopar radio repair connector but it's super expensive. Or if some one knows where to source just the pins and not the whole connector that would work too
R4M
do you know what the wires look like and harness from the RA1?
I have a backup camera in the rearview mirror, and the dealer I bought the truck from, forgot to install the camera, when they changed my pickup bed to a utility bed.
having trouble locating the wiring, and what it looks like,
they are suppose to send me a kit,
would you mind posting a photo of what you wiring looks like from your ra1 system?
baum
savage, mn
2015 Laramie
you can just put the pins into the factory connector. i did this on my old '13. unfortunately i dont remember what ones anymore as that was 4 years ago.
search around on here there are many descriptions that call it out. maybe in the diy section also
R4M
pins
what do you mean by pins?
do you have to de-pin a connector to repin a connector?
I was under the assumption everything was there I just had to plug it in.
there were two connectors in a pack in the glove box, not sure what they were for....
R.L.K.
Bristol , Tn.
To reroute the backup camera from the mirror to the radio , you need to reroute 3 ea wires from the connector behind the passenger's side air vent sockets 8 , 9 &10 to the radios C-1 connector @ sockets 31 , 32 & 33.
I'd suggest contacting M2Mods a vendor here and ask for a custom harness .
R.L.K.
Bristol , Tn.
Here's a link to M2Mods thread on harnesses they offer , to include the one you need sir .
I highly recommend using M2Mods due to the professional products they produce and the assistance and service after the sale if required . Just send M2Mods / MPGRIMM2 a PM .
Good luck Sir !
http://www.ramforum.com/showthread.php?p=1458161
R.L.K.
Bristol , Tn.
And another link you may find helpful.
http://www.ramforum.com/showthread.php?p=1332221
If you opt to keep your oem mirror with the video display you can have the backup camera displayed on both the mirror & the radio . This has been done by a few guys , but then you'd need to get some other option for a microphone for full Bluetooth capabilities of your new radio .
noclass
noclass
I know how to do it just not where to sorce just the pins I need with out buying an expensive mopar repair connector. I did end up ordering a harness from m2mods
noclass
noclass
I've already got a microphone mirror and wiring I need to install it
R.L.K.
Bristol , Tn.
Looks like you are set Sir
