jschwanke84
- Aug 17, 2016
- 159
- 57
- 2016
- Hemi 5.7
Hey guys. I have a 2016 Hemi 5.7 with about 6500 miles on it. Just this morning on my drive to work the stereo (which is the UConnect 5.0) started having an issue. I was listening to SXM radio and everything is good, then I go to change the volume and it changes but the volume numbers don't display. I then try to change the XM channel and the it responds to my touch and moves to the preset button that I selected, but it doesn't actually change the station. Then I try to switch out of XM and into regular radio using the actual radio button, not the touchscreen, and nothing happens... After that the touch screen stops working entirely, music keeps playing this whole time by the way, and eventually the whole thing seems to reset and power cycle itself.
It goes black, comes back after 20-30 seconds, shows the RAM screen, then the usual warning screen where you have to touch "accept" and then goes back to the radio like normal. At first after the reset everything is working fine so I figured it was just a random thing, but then it does it again. And again. And again. In about 5-7 minute intervals it keeps going through this same process on my entire drive to work. I stopped halfway and turned off the truck entirely and then back on seeing if that would help but it kept doing it.
Anyone every experienced this or had something similar? Is there a hard reset or something I can do? Obviously I am under warranty still and can take it into the dealership but figured I would ask around first to see if it is just something minor I can fix on my own.
Thanks for any input!
