Jim's Express
- Jun 8, 2015
- 94
- 20
- Northern Ontario
- 2015
- Hemi 5.7 6 Speed
I bought a Bayou Goat GPS mount for the top tray that says RAM on my 15 Express. I drilled a small hole in the tray and ran the power cable down behind the radio and out of sight. I removed the trim at the very bottom of the console and had the cable come back up the outside. There is about 3-4 inches of cable sticking out that ends in a male USB plug.
I bought a 90 degree USB adapter so the cable would sit flush and not stick straight out when I plugged it into the USB port. This is the one on the right side of my pull out tray at the bottom of the center console.
I noticed that with the truck turned off and no key, the charge light on my GPS was always on, 24-7. I didn't want that so I checked to see if there was some fuse I could switch so I change it from always live to only live with key on. I've had this option on previous vehicles.
Unfortunately there wasn't, so I stuck one of those cigarette lighter USB adapters in the 12v outlet on the left side of the pull out tray and plugged the GPS there. Good news is, it only charges when the truck is running, bad news is, it sticks out.
Just thought I would share....Jim
