spankis
- Jul 24, 2012
- 127
- 10
- 2007
- Cummins 6.7
07 Regular Cab - Best 4 Speaker Size /Location /Configuration
So I've decided its time to replace the stereo and speakers in my truck, and I find myself at a crossroads. I'm very open to opinions.
Currently:
-Factory 4-speaker Non-Infinity Stereo (no factory amplifier)
-Factory 5 1/4" Speakers in rear of cab
-Factory 6x9" Speakers in Front doors
-NO 3.5" Speakers in dash (mounting buckets exist, no factory speaker wires to dash)
Planned:
-Replace factory headunit with aftermarket (likely Pioneer)
-Remove factory door speakers and factory speakers in rear of cab, replace with some combination of 4 new speakers (size and location to be determined)
Here's where I need advice.... I could replace the factory 6x9s in the front door with better 6x9s, and replace the rear 5 1/4" with an upgraded 5 1/4". Also, instead of 6x9s, I could also install component 6.5s in the front doors with an adapter ring/spacer. A third option could include ditching the rear cab speakers altogether, and wiring quality 3.5" speakers in the dash locations.
I'm up for adding a small 4 channel amp under the seat or behind the dash if its worth doing. I have no plans to add a sub at this time, and would likely only do a slim 8 or 10" down the road. Obviously I'll be missing the low lows without a sub, but what combination of 4 speakers will give me a the most full range system, without huge gaps in frequency? Thanks in advance!
Currently:
Planned:
