dodgeman70592
- Jul 26, 2011
- 200
- 15
- Youngwood, PA (currently)
- 2008
- 6.7 CTD
Well, after much deliberation, it's time....
I am starting the install tomorrow evening and hope to have her done by next weekend. I am figuring somewhere in the 40-45 hour labor time frame.
First she will be deadened with some CLD tiles from SDS. Then will come some 1/8" MLV equivalent, then 1/8" CCF. This will be done from firewall to back wall, outer door skin, inner door skin, and door cards.
Then, we move to the front doors. New wire and 1" recessed MDF baffles for the midbass. Along with some extruded butyl rope spaced out along any crossmember and side impact protection beams to let any water drain.
Then to the rear doors. Same as the front, using 1" recessed MDF baffles for the rear comp set. Butyl rope for impact beams, etc.
Once all is deadened, and door speaker areas are done, next will be the wiring. Two, 5 channel amps will be powering the complete system. Every last wire, RCA, connector, fuse, etc will be only the flagship line from JL Audio.
Once wiring is ran, soldered, heatshrunk, etc. the carpet will go back in along with all the door panels, A, B, C pillars, and back wall pieces.
Next will be the new kick panels to house the front comp sets. They will be modded and connected accordingly.
Finally, the new dash speakers will be set into their new home.
Sub box goes in next. drivers seat (the only one that matters), then the tuning begins.
Equipment list:
Head Unit- Eclipse AVN726E
Processor- Coustic XM6
Amplifier- (2) JL Audio HD900/5
Sub- (2) JL Audio 12W6V2
Midbass (front doors)- JL Audio Evolution ZR800-CW
Front (kicks)- JL Audio Evolution C3-650 6-1/2" convertible components
Rear- JL Audio Evolution C3-525 5-1/4" convertible components
Dash- JL Audio Evolution C2-400x 4" coaxial
Speaker wire- JL Audio XC series 16ga
Sub Wire- JL Audio XC series 12ga
Interconnects- JL Audio XB series "Blue"
Kicks- Q-logic
CLD- Sound Deadener Showdown
CCF- Sound Deadener Showdown
MLV- custom
While I am at it, there is also a couple other mods (not audio related) that will get done as well to enhance her "looks"
I will update as much as I can with pics, and if there is any questions along the way (or something you are interested in seeing a pic of) just ask.
Equipment list:
Kicks- Q-logic
MLV- custom
